52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Double sloped hipped roof
2 Posts No Rating |
has anyone successfully modeled a double sloped hipped roof? I am currently modeling an existing project with such a roof, and I am having a hard time getting the roof to work properly. Any suggestions?
2 Posts No Rating |
I'm working in REVIT 2010 by the way...here is a screen shot
5 Posts No Rating |
Hi, I usually try to simplify the roof like drawing complete roof and then using the opening tool for cleaning unwanted part of roof.
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
gday,
petep it looks like to me you are pitching the "flatter" of the 2 roof pitches at same ht as adjacent roof planes.
And the upper roof is slightly steeper than the adjacent roof pitch so that ridge ht is maintained.
if that is the case, the hip corner should have a bit of crank in it , at the point of change in roof pitch.
its not apparent from the view angle of the pic shown if the hip has a bend in it. in other words, in a plan view the hip would be at 45 deg from ridge to change in pitch and then veer off to compensate for the lesser slope.
hope that all makes sense.
the other thing to try, maybe make it as 2 roofs, and merge them together, cut out overlaps then join geometry.
regards
geoffm
Creating a Dormer in Hipped-Gable Roof. |
Fri, Oct 5, 2007 at 7:15:11 AM
Gablet to hipped end roof. |
Fri, Apr 23, 2004 at 3:40:44 AM
hipped roof beam |
Thu, Mar 31, 2005 at 9:37:20 PM
Rotation angle of double angle roof bracing. |
Mon, Jan 21, 2008 at 2:51:55 PM
Double Sloped Steel Joist |
Thu, Dec 23, 2010 at 8:35:13 AM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
