98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> metal wall panels
2 Posts No Rating |
see jpg.... what is the best way to draw this typ of building? i need metal wall panels with varying widths, lenghs and colors. can this be done?
I am working on a similar project right now. What I have done is to model the wall with horizontal reveals since those are uniform/fixed spacing. The vertical reveals I add in place. Now the problem. If you do the above, you will not be able to split face tochange the wall material of the various panels. In hind-sight, you could probably not include the wall reveals in the wall definition and then you could split the face. However, you have the problem of the curved walls. You will not be able to split face there. So you may have to do something similar to what we did. Our solution for the colors was to have an overall base color for the wall. The for the accent color panels, we add an in-place family of the correct size just a fraction in front of the wall. Nothing you can see in plan. This is probably best done as a parametric , face-based family with an instance or type based finish. Place the family once in elevation and copy it to the farious locations and stretch/shrink in place. The curved panels would have to be a seperate family and probably not face based.
2 Posts No Rating |
Thanks. I will try that.
Need rendering material for metal roof and metal wall panels. Red paint finish. |
Thu, Oct 26, 2006 at 5:09:26 PM
metal wall panels with rivets at the corners |
Sat, Jul 28, 2007 at 10:53:01 AM
Raised Glass/Metal Panels for Curtain Wall |
Thu, Dec 20, 2007 at 6:43:04 PM
metal panels |
Mon, Dec 20, 2004 at 6:01:44 PM
Perforated Metal Panels |
Mon, Apr 26, 2010 at 11:46:49 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
