Forums >> Revit Building >> Technical Support >> Roof by face, how-to
7 Posts No Rating |
hello, hello this is a post how-to construct in revit, a floating roof structure as seen on sanaa project in lausanne and my student project based in palermo. as far as i understand, the best command to do this roof is to make a roof by face. - but how would i do this with this project? - what i think is to make walls with curvature profile on top base and make them invisible in renderings? thanks for help! h
Architect student - twitter.com/proooo @ The Bergen School of Architecture, Bergen - Norway www.bergenarkitektskole.no |
With only those images I can't tell you how to build the roof because i don't know the shape you want to the roof, if you can provide more images with the shape you want I bet we can help you.
7 Posts No Rating |
hello again, thanks for your reply. generally i want to create a wavy surface out of concrete, serving as both a public floor but also a roof structure over rooms underneath it. i figured that i will create a mass - because the roof or floor commands are structured into standard template roofs. - so my question is: how to model a wavy surface in general? i know how to do a mass structure, but cannot edit the profile on the z axis, only in work plane constrained by x and y (horizontal). hope you understand? h
In Conceptual mass create the profiles like you want (image 1), then select the profiles and click on "Create form" (image 2), after this, you can turn that form in "X-ray" and select any point, edge, or face and manipulate the gizmo (image 3), when you have your form (in this case Roof) like you want click on "Load into project", go to "Roof > Roof by face" and select the face (image 4). HTH
Edited on: Tue, Nov 30, 2010 at 12:29:12 PM
7 Posts No Rating |
thanks alot. this recipe will surely do it. i will pursue this approach during the afternoon thanks alot!! h
Roof by Face and Wall by face tools |
Tue, Jan 28, 2014 at 6:31:03 AM
Roof by face, wall by face clean up |
Tue, May 29, 2012 at 4:57:43 AM
two dormers in the same face of roof |
Fri, Apr 12, 2013 at 3:57:28 AM
Roof by Face on curved mass surface issue |
Mon, Oct 5, 2015 at 12:39:58 AM
CURVED MASSING FOR ROOF BY FACE |
Tue, Jul 20, 2010 at 5:24:24 AM
Members: | 2019229 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
