Forums >> Revit Structure >> Technical Support >> Scaling furniture
Id like to change the size of a table that I downloaded from this site. I cant edit type or use the scalign tool, the scaling tool is greyed out and theres no section under type to change the dimensions.
----------------------------------- In the day of my trouble I will call for you, for you will answer me.~ Psalm 86 |
It all depends how the family was created, if the family was created in Revit (parametric) you don't need to "Scale" anything, just select the "Table" go to properties, if you don't see any dimension in instance go to "Edit Type" and check if you don't have parameters like "Material and Dimensions" to change, if the family was created in Autocad, Sketchup or other software you need to edit that family and scale inside the family. HTH
Yeah, there were no dimensions in type. Ill try editing the family. Thanks for the info.
Furniture Tags & Sketchup Furniture Components |
Fri, Dec 4, 2015 at 9:35:34 PM
Difference between Furniture & Furniture Systems |
Thu, Jan 4, 2007 at 2:37:48 PM
Turning off Certain Furniture |
Tue, Jun 20, 2006 at 2:09:53 PM
Filled furniture |
Fri, Jul 17, 2009 at 12:06:57 PM
Furniture X Furniture Systems Families Templates |
Fri, Mar 17, 2006 at 6:16:19 PM
Members: | 2098010 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
