148 Posts No Rating |
I am having a few issues with wall sweeps, I hope that someone can advise ... 1. I am unable to access the "2.Click Modify | Wall Sweeps tabWall Sweep panel Modify Returns. " command. The only option I am given, when selecting a sweep (like a gutter) is "add/remove segments" Please advise on how I can access this option. See attached DOC file ... 2. I have created a 'metal flashing' sweep RFA. I have added this sweep to a wall family "EW Brick on Stud". It works fine, except for 2 situations:a. if the wall is attached to the floor/roof above, the sweep disappears, and b. the sweep will not wrap around the end of a this wall segment. andc. The flashing sweep is cut by windows, but I want to have it continuous. I have tried to set the sweep to be both cutting and non-cutting, with no success. The ‘unjoin elements” option will not resolve the issue and I must cancel the operation. You can see how item 2b takes me to the question #1. I can not find a way to properly terminate this sweep. Due to the complexity of the model and the ongoing management of a manually added sweep, I do not wish to add the sweep manually, if at all possible. Your assistance would be greatly appreciated.thank you
Ian Shafer
Principal Consultant
True North S&F Consultants |
