102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> Is exporting model patterns from a 3D view possible ?
22 Posts No Rating |
Hi, I am trying to export my building to solids in order to create a lasercutting file. I am expecially interested in having the wall surface model patterns (metal panel walls) export as well in order to be able to score them with the laser. So far I have exported to DWG as solids but no patterns/hatches come through. Exporting to solids is important to avoid triangulation of the surfaces and also to maintain the wall join conditions which have been modeled in Revit to match the way they will be glued up in the physical model. Is there ANY file format, option, plugin, 3rd party software... which will make exporting a 3D model patterns possible from Revit ? Thank you for any help. JF
material patterns rotate when exporting to a DWF revit 2015 |
Thu, Jan 22, 2015 at 12:41:59 PM
Where do model patterns go? |
Thu, Sep 24, 2015 at 9:37:41 PM
Model Patterns |
Wed, Dec 12, 2007 at 3:38:41 PM
No Surface Patterns in Perspective |
Thu, Feb 1, 2007 at 4:55:53 PM
Model Fill Patterns |
Tue, Jun 22, 2010 at 11:35:19 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
