Forums >> Revit Building >> Technical Support >> Stair UP/DN Transparent?
148 Posts No Rating |
Greetings. Does anyone know how to change the UP/DN text for a stair to Transparent? I am unable to locate this setting. Thanks. Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
You can try following: 1. Pick thr stair , then right click to show the " Element Properties" 2. In Graphics, un-check Up lable, Up arrow, Down label and Down arrow.
Thank you for your thoughts, but this only controls the visibility of the arrow/text and not the opaque/transparency of the text. (unless I missed something obvious ...) Ian
Ian Shafer
Now I know what are you looking for. If the "UP" "DN" block your stair, you can try the following: 1. Move the cursor to "DN" to hightlight it, then you can see a blue dot, you can drag that out fron the step. 2. Or you can point the cursor to the "DN", and right click, then click "Override graphics in vew/By element, then you can select the options.
Thank you ... that does accomplish the goal ... for a particular stair on a particular view. But I am hoping to find the solution to control these text graphics (stair text) for the entire project, much like the opaque/transparent settings for dimensions and text. Is this not available for stair text? If not, then I suppose that this will have to be a wishlist item ... Ian
Ian Shafer
I personally do not like the up/down arrow so I always turn it off and use a text note.
Transparent Text on Stair Labels |
Wed, Feb 16, 2011 at 10:09:48 AM
Stair Visibility Issues |
Fri, Jun 7, 2013 at 8:58:58 AM
14
Transparent object |
Tue, Sep 14, 2010 at 1:18:34 PM
Stair Visibility - Revit 2008 |
Tue, Nov 11, 2008 at 7:42:38 PM
Creating transparent material such as 3FORM |
Wed, Aug 26, 2009 at 8:09:06 AM
Members: | 2119161 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
