49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Rendering in revit
9 Posts No Rating |
I am trying to render a building with white interior and exterior walls and I am using 8" recessed lights. Whenever I render- it all seems very yellow , not showing the white wall at all. What is the best way to show the white walls? change the light color - how would I do that? Or is there another way ? Thanks alot !!
After you finish a render, you can adjust the exposure down at the bottom of the render dialog box -- you probably want to turn the warmth of your render down a bit. If that doesn't quite do the trick, you can edit the light family to be more of a white light, and turn up the kelvins on the light source.
9 Posts No Rating |
Thanks - I will try that !
I should probably explain--you change the Kelvins by opening up the light fixture family, and then going to "Family Types" The button with the four blue cubes next to properties in the upper left. Scroll down to "initial color" and pick a different type of lightbulb, or specify a custom. Mmmmm... Low pressure sodium... not.
revit rendering |
Thu, Oct 14, 2010 at 8:33:24 AM
Revit MEP 2009 Rendering |
Thu, Mar 5, 2009 at 8:35:55 PM
What is the best revit/rendering engine combo? [ 1 2 3 ] |
Tue, Feb 3, 2015 at 9:40:52 AM
31
Revit 2009 Rendering Problem(Black screen) [ 1 2 ] |
Mon, Apr 1, 2013 at 2:45:28 PM
27
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
