106 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> STL export tips
Mon, Nov 22, 2010 at 10:33:34 AM | STL export tips
esahnow
I've downloaded the .stl export add-on for Revit 2011 and will be attempting my first 3D print later this week. As I build my Revit model, I'm looking for tips/tricks for handling problems that others have found. Specifically, how are wall/floor/roof layers viewed by the .stl file conversion? Is it better to use generic wall/floor/roof components?
 It is an existing brick building with many level changes and openings. I will be printing at 1:10 and 1:30 for various site plan models.
 Also, exporting topo from Revit to .stl file: Can it be done?
Thanks for the help all!
Edited on: Mon, Nov 22, 2010 at 10:46:31 AM
Eric Sahnow
Project Lead/Designer
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:06 PM
.stl file creation?
Thu, May 17, 2007 at 12:50:54 PM
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:32 AM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:42 AM
Exporting Topo to STL as a solid for 3D Printing
Fri, Feb 9, 2018 at 4:51:22 AM
Page generation time: 0.8715
