93 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Arraying Louvre Problems - Constraints not satisfied
Mon, Nov 22, 2010 at 7:52:26 AM | Arraying Louvre Problems - Constraints not satisfied
PatrickReynolds
PatrickReynolds Avatar
Hello all,  I'm trying to put together a vertically-arraying louver curtain wall panel.  I've got the louver system set up, and it arrays correctly, but whenever I try to assign a height parameter based on the height of the curtain wall panel, it messes up.
I had to use a system height parameter in the system family I'm embedding in the curtain wall panel; as a result, whenever I import it into a project and assign it to a panel, it maintains that height instead of expanding to the full height of the panel.
I tried to remedy this by assigning a dimension parameter to the panel height in the panel family, and then associating the system height variable to taht dimension parameter, but whenever I change that variable in the types menus I get a constraints not satisfied error.  Moving the panel dim. manually is fine, but editing it with the parameter screws it up.
How it is now I can work with it, but I'd like to fix this so that it will takes me less time; I'm putting a ton of these over a skyscraper project for school, and would like it to take the least amount of time possible.  I've included the family file here.  Thanks for the help
Constraints Are Not Satisfied when opening file - Revit Architecture 2008
Wed, Aug 27, 2008 at 9:46:30 AM
Louvre Window
Wed, Jun 30, 2010 at 10:45:56 AM
Constraints not Satisfied
Thu, Jul 2, 2009 at 6:12:44 AM
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:17:24 AM
constraints not satisfied... driving me crazy
Thu, Nov 7, 2013 at 1:11:39 PM
Page generation time: 1.9080
