Forums >> Revit Building >> Technical Support >> LEVELS
65 Posts No Rating |
Hi, I have a very extensive project that has some levels I want to erase. The problem is that they are bounded to many objects. For example I had two levels of basements, but I donĀ“t need one of them. Is there someway to erase that level without erasing part of my project and/or automatically relate them to another level? because I changed a lot manually but I don't thing I finish changing them? Hope I explainded Myself. Best Regards,
You probably should just hide that level off in all views. Much easier.
Ok, it is what I'm doing, but when you have a project of 70+ sheets its not that easier... maybe if there where an option like "hide on all views" it will be a lot easier....
You can drag the level in 3D setting off to the side so that it does not intersect any view.
Genius !!!, That will save me from hours of formatting views. Thanks !
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ] |
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels |
Thu, Mar 11, 2010 at 2:38:19 PM
Members: | 2101453 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
