Forums >> Revit Building >> Technical Support >> how to split a way at an acurate location
77 Posts No Rating |
when I split wall, sometimes, it's hard to cut at certain location. I tried to split it first, and then drag the interface to where I want, but splitting then disappeared, the two walls joined after I drag the interface. Does anyone have the similar experience?
Create an elevation to that wall. Create there an detail line.Then click on the split icon, and click split on the edge of the wall ( press the tab button until it gets purple), but over the detail line.
Edited on: Thu, Nov 18, 2010 at 11:44:07 PM
What nasty is telling you, indirectly, is that Revit is very precise at splitting an element at an intersection if there is one. So... give yourself something as a reference.
Parts shape handles Revit 2012 |
Wed, May 9, 2012 at 2:00:55 PM
Making a Clean Split |
Sun, Jul 11, 2010 at 1:51:14 PM
Split face aournd a corner... |
Tue, Aug 25, 2009 at 2:14:22 PM
changing material on a wall |
Thu, Apr 9, 2015 at 7:02:47 AM
Where does it start and ends the slab? |
Wed, Dec 23, 2009 at 11:11:08 AM
Members: | 2123323 | Objects: | 23210 | Forum Posts: | 152316 | Job Listings: | 3 |
