143 Users Online (142 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall hosted arena seat
Tue, Nov 16, 2010 at 11:45:26 PM | Wall hosted arena seat
chasetifer
I made an arena that has offset floors for different seating levels and base offset walls connecting between each of the floors.  I now have created a custom wall-hosted seat.  After loading it into the project I can place it on walls that extend to the base of the view I'm working in, but not the walls where the base is offset.  Is there a way to work around this?  Thanks.
Wed, Nov 17, 2010 at 6:40:54 AM | Wall hosted arena seat
Not sure why you would create a wall hosted family for this.... seems there are better options.
We would probably have to see the family to give you an answeer but I suspect your family's location is still dependent on the floor level. Is there an offset dimension in the family?
Wed, Nov 17, 2010 at 9:27:58 PM | Wall hosted arena seat
chasetifer
They are wall hosted because the tiers of seating are on a slight arc (easier to position than if they were floor hosted... though I suppose I could've just done a face hosted family).  Anyway, I figured out what the problem is... placing the component is view specific.  For example, I had a "concourse" level plan open and it would only let me place the component on walls whose base was "concourse" level (not offset from concourse) .  If the wall was offset, it wouldn't. What I had to do was orient the concourse level to the default 3d view (so I could avoid having to work around the rest of the building which is already slowing my poor college student computer down), and then I could place them on the proper wall(s) within that view.  Once it was on the wall, I was then able to edit (and copy paste) in any view.  A little backwards, but an easy enough work around.  Now only 8000 more seats to go.... :\
Arena Seating Bowl
Thu, Nov 13, 2014 at 11:48:14 AM
Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 3:40:49 PM
Joist Seat Elevation?? HELP!!
Fri, Apr 11, 2008 at 10:35:49 AM
Wall hosted components in groups............ [ 1 2 ]
Fri, Nov 3, 2006 at 8:09:00 AM
15
Seat count in bench family
Tue, Apr 29, 2014 at 10:36:15 AM
Page generation time: 1.2987
