44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Ripped Structural Slab
Tue, Nov 16, 2010 at 7:47:49 AM | Rippled Structural Slab
cundall
Does anyone Know how to do a Rippled Structural Slab like the profile in the attachment ? i cant seem to find any thing on how to do Ripped Structural Slabs any where !
Edited on: Tue, Nov 16, 2010 at 9:16:24 AM
Edited on: Tue, Nov 16, 2010 at 10:14:43 AM
Tue, Nov 16, 2010 at 9:29:36 AM | Ripped Structural Slab
3.5 Stars: 395 Votes
Do you mean ribbed using a metal deck?  Sorry but I will not open a dwg when a simple image could have worked.
We don't model floors like this.  We add detail components to appropriate sections and details.
Tue, Nov 16, 2010 at 9:47:30 AM | Ripped Structural Slab
cundall
its an old slab, i dont know how to make it so i just came on here for help !
Tue, Nov 16, 2010 at 9:53:57 AM | Ripped Structural Slab
cundall
here is a jpeg of the slab profile
Tue, Nov 16, 2010 at 10:17:14 AM | Ripped Structural Slab
As Isaid, we do not model something like this.  Create a masking region family that is the shape of the open area of this slab, then set it up in a repeating detail.  Create your floor as a full thickness, then in cross section views, drag this repeating detail across the bottom of the slab and it will create the apparent void areas.
Tue, Nov 16, 2010 at 11:17:52 AM | Ripped Structural Slab
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
revit structure models ribbed slab as the basic metal deck, it will appear flat top and bottom unless you view it in fine detail. you can change the direction of the ribs by changing the span direction.
Tue, Nov 16, 2010 at 11:21:58 AM | Ripped Structural Slab
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
here is a quick view
Attaching Structural Col to Structural Slab
Mon, Apr 30, 2007 at 10:05:24 PM
Structural Slab Levels on Plans?
Fri, Dec 22, 2006 at 9:42:09 AM
Creating a structural slab for analysis
Tue, Jun 5, 2007 at 5:08:16 AM
Slab vs. Floor vs. Foundations...Which do I use?
Mon, Feb 18, 2008 at 2:49:13 PM
Structural Slab profile
Fri, Jun 2, 2006 at 6:21:15 PM
Page generation time: 0.4848
