33 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> trusses not attacing to roof
Mon, Nov 15, 2010 at 4:45:25 PM | trusses not attacing to roof
hammer87
hammer87 Avatar
3 Stars: 4 Votes
For some reason, I cant get my trusses to attach to my roof in RAC 2011, i opened a new project and did a test and it worked fine. What am I doing wrong? Attached is an image of the problem, I am using the Howe flat truss, and the roof has a 6/12 pitch
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Tue, Nov 23, 2010 at 1:58:29 PM | trusses not attacing to roof
kbeegles
It may have something to do with the heel end of the truss....looks like the top and bottom chord meet at a point.  If the roof surface does not meet the intersection of the truss at that same point, you would probably get a geometric imposibility.
Maybe try adding a vertical "heel" member to the truss profile family so that it's height can go up or down to adjust to the roof offset from the wall bearing height.
The Leffler Group
Wed, Nov 24, 2010 at 1:01:39 PM | trusses not attacing to roof
hammer87
hammer87 Avatar
3 Stars: 4 Votes
I'm afraid I'm not quite sure what you mean, having a picture would help
Tue, Nov 30, 2010 at 10:40:46 AM | trusses not attacing to roof
kbeegles
This is the truss profile I'm thinking of....See if creating something like this gives you better luck.  I believe that the vertical member right at the heel will allow the top chord to attach at any height or angle, while the standard family that has the top chord meeting the bottom chord at a point will only allow the truss to attach if the roof is very close to the bearing point.
The Leffler Group
Tue, Nov 30, 2010 at 12:11:50 PM | trusses not attacing to roof
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Ok, thanks I'll try that. just have to modify the truss to be a mono pitch
Roof Trusses
Fri, Apr 11, 2008 at 10:19:16 PM
Roof trusses
Tue, May 23, 2006 at 1:48:35 AM
Roof Trusses
Wed, Dec 23, 2009 at 6:56:53 AM
How to make a roof consisting of rafters and trusses?
Mon, Feb 1, 2010 at 10:46:28 AM
Newbie - Roof trusses and overhangs
Fri, Jul 29, 2011 at 3:37:16 PM
Page generation time: 0.4649
