104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Attach columns to underside of ramp
Wed, Oct 26, 2005 at 11:42:43 PM | Attach columns to underside of ramp
nextvkin
I found a thread by Mr Spot with a solution for above - "Create a new column which has a void built into the family to cut the top with an instance adjustable angle..." Mr Spot, can you please show us how? Thanks.
Thu, Oct 27, 2005 at 12:22:46 AM | RE: Attach columns to underside of ramp
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Here is the column... Just quickly edited the standard metric rectangular column. Created a reference plane above the top level and constrained it to the top level. Then unlocked the top of the column and re-aligned it to the new reference plane. Then created a reference line with an instance angle parameter as you'll see and constrained its origin to the intersection of the reference plane and level. Then created a void and constrained it to the reference planes and column... HTH.
Thu, Oct 27, 2005 at 12:30:27 AM | RE: Attach columns to underside of ramp
nextvkin
Mr Spot, Thanks for your reply, I'll give it a go following your instructions. Unfortunately we havent got our 8.1 licence yet so can't look at your drawing but will do so as soon as. Yes it works very well as far as the angle goes, but how do I add a parameter to adjust the height? Post edited on 2005-10-27 01:47:44
Thu, Oct 27, 2005 at 3:14:37 AM | RE: Attach columns to underside of ramp
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Columns go from level to level and as such don't have a height parameter... simply change the top level of the top level offset in order to change its height...
Thu, Oct 27, 2005 at 3:40:14 AM | RE: Attach columns to underside of ramp
nextvkin
Got it, Mr Spot, Thanks again!
Wall attached to Ramp
Fri, Apr 19, 2013 at 1:19:57 AM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Ramp railing
Thu, May 22, 2008 at 4:08:47 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:09 AM
Attach Wall up to Roof
Tue, Oct 2, 2007 at 3:57:57 AM
Page generation time: 4.8400
