34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> coping the girder
Sat, Nov 13, 2010 at 12:57:31 PM | coping the girder
arcnap09
hi all,
If you have any ideas to connect these two member i will be appreciate. I can not control coping of the girder to column. thank you very much
Sat, Nov 13, 2010 at 2:30:10 PM | coping the girder
4 Stars: 203 Votes
You want to connect that Column to the bottom of the beam or to the top of the beam? You can create a ref. plane and use the "Cut geometry" tool to cut that column, if this is what you want...
Sat, Nov 13, 2010 at 3:16:51 PM | coping the girder
arcnap09
Thank you very much, Cut seems working  well.
Truss - coping frame members
Mon, Aug 16, 2010 at 5:51:36 AM
Modifying Existing Family
Thu, Nov 25, 2010 at 12:29:16 PM
Finish Profile at Stone Coping [ 1 2 ]
Tue, Jul 29, 2008 at 1:20:48 PM
16
Lattice Girder Column
Fri, May 25, 2012 at 6:36:26 AM
JOIST GIRDER INQUIRY!
Mon, Jan 28, 2008 at 5:23:14 AM
Page generation time: 1.8223
