80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sketchup imported
Fri, Nov 12, 2010 at 5:29:35 PM | Sketchup imported
brandino
Is there a way to bring in a sketchup model into Revit and allow it to be manipulated?  I've brought sketchup models in before, but it comes in as a solid uneditable block.
Sat, Nov 13, 2010 at 5:28:17 AM | Sketchup imported
4 Stars: 201 Votes
NO, if you want to "manipulated" that model, you must do that in SK, what you can do is: "LINK" that file then if you need to change anything do it in SK, save the file (with the same name) then in Revit go to "Insert > Manage Link" select the CAD file and click on "Reload" and OK, your SK-model will change.
Sat, Nov 13, 2010 at 12:45:43 PM | Sketchup imported
brandino
Thanks Typhoon.  What about applying materials?  I haven't been able to apply materials to an imported sketchup file in Revit.  Is there a way that I am unaware of?
Sat, Nov 13, 2010 at 1:59:38 PM | Sketchup imported
4 Stars: 201 Votes
There are hundreds of threads about this same question here in the FORUMS, if you search for "Sketchup Materials" you will see, meanwhile check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=5969
 and this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=18203
and this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
there are lots of them, search for more if you want to learn.
imported sketchup drawing
Thu, Oct 8, 2009 at 9:40:37 AM
Imported object transparent faces
Tue, Mar 15, 2011 at 2:44:52 PM
Sketchup imported into Revit Error and Crash
Wed, Nov 12, 2008 at 5:17:12 PM
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
PROBLEM with assigning materials in imported components from Sketchup
Sun, Oct 23, 2011 at 5:01:41 AM
Page generation time: 0.3493
