67 Users Online (66 Members):
Forums >> General Discussion >> Wishlist >> Stair Flexibility // Rotate Command
![MYoung Avatar](user_avatar/18343.jpg)
53 Posts No Rating |
I'm satisfied with nearly all of Revit's features, but the stair sketching features are extremely frustrating and difficult to adjust. When in sketch mode: - on a 2-flight U-shaped stair, moving one flight causes 'elements to be deleted,' which is the intermediate landing. The only work around I've found is clicking each riser and entering the tread with until the stair is where I want it... which takes too long to do. The landing should adjust according to the stair relocation (which is the case when you click and drag the flight, however you can't drag it to a snap when doing this).
- Risers aren't joined to the boundary line, so when the stair width is adjusted, one must trim the risers to the boundary line.
Secondly, (although less annoying) the rotate command should prompt you for the point of rotation instead of defaulting to the middle, because it is practically never the case that an object is being rotated about its center. It would be the same as having the move command default snap to the center; it just doesn't make sense.
I rarely sketch the stair. I have found it faster and easier to let Revit lay it out automatically then I adjust afterwards. Very easy to change it. As far as rotating anything in Revit - just click on the rotation center and move it.... Forget your CAD
Stair Command |
Wed, Aug 31, 2016 at 3:32:54 PM
the promises of the new stair command in Revit Architecture 2013 |
Fri, Dec 14, 2012 at 9:17:29 AM
rotate project command |
Mon, Feb 27, 2006 at 3:42:53 AM
copy rotate and repeat command |
Thu, Dec 22, 2005 at 3:44:41 AM
Unable to rotate/align surface pattern on stairs |
Thu, Aug 28, 2014 at 7:29:20 AM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
