73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Customizing Families and objects
Wed, Oct 26, 2005 at 2:42:12 PM | Customizing Families and objects
Hulsberg
I know that I can customize my own family by opening it as its own seperate file. But I am curious if there are any other methods to doing so. Can I customize with a different program in import into Revit. A problem I find with the current way of customizing is that it is a time comsuming process.
Wed, Oct 26, 2005 at 4:07:46 PM | RE: Customizing Families and objects
TomDorner
4.5 Stars: 25 Votes
Revit families can only be developed or changed in the family editor which is integral to the Revit program. A properly desinged family however will let you creat another instance of itself by duplicating, naming it and then changing the parameters that the family contains. For example, a door that has 36" x 7'-0" size but not 36" x 8'-0" size can be made into the larger size by going to the properties of the smaller one, duplicating it and changing the height parameter to 8'-0". Another option is that 2D and 3D CAD geometry can be brought into a family. HTH Tom
Converting ArchiCAD objects into Revit families
Thu, Jan 17, 2013 at 9:43:30 AM
Transparent Families
Thu, Jul 15, 2010 at 8:35:27 PM
Multidirectional moving of objects w/in families
Mon, Jun 28, 2010 at 9:08:36 AM
How to Scale Objects in Revit
Fri, Aug 25, 2017 at 1:13:48 PM
Revision Numbering
Wed, Jun 17, 2015 at 12:39:25 PM
Page generation time: 1.9951
