Forums >> Revit Structure >> Technical Support >> Structure Connection Family Template?
3 Posts No Rating |
Hello. I tried to search after similar post, but could't find any. If there is, please don't shoot me.  I want to create new Structure Connections Family. but I can't find any family template for that. Yea I know, I could take existing family and modify it, but I am wondering if there is a clean family template for Structure Connections. Thanks,Martin
One of my dreams is to master Revit. I have long way to go before achieveing this goal, buy I am learing new things every day getting me closer and closer. |
You can use one of the other templates (Generic Model, for instance) then in family categories and parameters change it to structural connection. There is no option in Revit to save as a family template, but if you set up a family the way you want your template set up, you can then change the families file extension from .rfa to .rft and it will then be a family template.
3 Posts No Rating |
Thanks for help.I tactually came to same conclusion, but needed confirmation.
4 Posts No Rating |
HI, I realize this is an older post, but if you're still looking to add structural connections inside Revit, you can try SDS/2 Connect. It creates the families for you, helps you design the connection, apply the materials and backs the connection with code-based design checks.
See for yourself here: http://www.youtube.com/playlist?list=PLCBB2A3F56AECECEB&feature=plcp
If you're interested you can download a trial at http://sds2connect.com/trial
Connection Design for Revit Structure |
Thu, Jan 12, 2012 at 11:26:26 AM
Mechanical Revit Family with Multiple Connection Possibilites |
Wed, Dec 2, 2009 at 9:38:17 AM
steel connection |
Tue, May 13, 2008 at 4:48:50 AM
Moment connection problem |
Tue, Apr 22, 2008 at 4:56:27 PM
2011 conduit connection |
Thu, Jun 10, 2010 at 1:15:55 PM
Members: | 2115836 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
