54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Visibility Graphics and printing
Thu, Nov 11, 2010 at 2:25:50 PM | Visibility Graphics and printing
nwmanj
I am having issues with our prints coming up light. We have gone into visibility graphics and tried to set up colrs. Even groups are printing light. Changing line weights doesn't help much no matter what we do. I check the VG in our linked i models. Is there and easier way of setting up our colors and prints?
Thu, Nov 11, 2010 at 3:38:21 PM | Visibility Graphics and printing
Are you printing in color?  That could be part of your problem.  Some colors don't show up well.
Are you printing directly from Revit or through PDF then printing that?  If directly out of Revit, make sure your printer driver is the latest.  You might try printing to a PDF then printing that and see what happens.
In revit, all linework is controlled pen size by your option styles and penweight tables.   The defaults shgould have been close to what you needed.
Or have you not told us everything and what you are printing are imported or linked CAD files because that is a different issue?
Fri, Nov 12, 2010 at 3:14:25 PM | Visibility Graphics and printing
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Printing thin?  Or printing light?  Your line weights should be standardized.  If you've played around with them, odds are they're not in good shape.  An unreasonable scale will also make your line weights a moot point when a view is scaled to fit to a page for printing.
What's fun about revit is that what you see in your screen is what will print on the page.  If you don't have the 'thin lines' button checked.  Do the screen line weights look like you want them to print??
visibility graphics problems-please help!
Sat, May 28, 2011 at 4:33:54 PM
Object Style / Visibility Graphics
Thu, Aug 5, 2010 at 3:21:26 AM
How to apply Visibility/Graphics Options to other drawings.
Tue, Jan 10, 2017 at 12:54:11 PM
Visibility Graphics - Linked Models
Fri, Oct 4, 2013 at 7:31:14 AM
Wall and interior elevation visibility graphics settings.... [ 1 2 ]
Thu, Aug 2, 2007 at 9:29:36 AM
15
Page generation time: 0.6203
