Forums >> Community >> Newbies >> using views in other revit projects
34 Posts No Rating |
my work involves small scale residential projects (extensions and new builds) my work flow is basically....... firstly i prepare a full set of existing plans and elevations as one revit project and then i prepare a set of planning drawings saved as a second revit project and then on some jobs i then prepare a set of construction or building regulation drawings again as a separate file on which i want to use some of the plans from the first file, the existing plans and elevations project. i have sometimes exported views from the first project as dwg's and then imported them into the required project but this seems a little contrived and the colours are never as i want them. i wonder if it is possible to use specific views from one projects (ie a floor plan) and bring them into new separate revit projects? any ideas would be gratefully received....
How about opening the existing file and saving it as your new project - then use what you want.....and add to it as needed?
WWHub - that is exactly what i do when i go from proposed planning drawings to building regulation drawings. the problem is that on the building regulation drawings (which show any modifications not the original layout) i still want to include the existing plans which are on the first set of drawings.
Drawings... you mean CAD?... No - I see you mean revit from your first post.... Again... why not start with your standard project and add your "existing" in that file - not a seperate file. It could be in a "design option" which is really existing and you control everting through VG. Or... Build your "existing" in this project in a different location ... a seperate building. Again - all in this one project.
Thanks WWHub - i think i need to research "design options" as i have not used these previoulsy but sounds like this could be a way forward and thus keep all 3 options in one revit project??
23 Posts No Rating |
Here is an intro on Design Options.... http://www.revitzone.com/revit-fundamentals/117-design-options-an-introduction Can I please ask why you save different Revit Project files for each stage of your project? I try to keep my project in one master file- right from concept study through to working drawings. But I am always very interested to hear how others use Revit in different ways and why so. Many thanks Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Resources |
Views in Families and Projects |
Fri, Sep 28, 2012 at 11:12:14 AM
exporing detail view, drafting views, + legend views to other revit projects 9.1 |
Thu, May 3, 2007 at 4:33:32 PM
Remove Working Views from Revit Projects with Python Shell Script |
Mon, Mar 25, 2013 at 12:43:53 PM
Coping Views between Revit projects. is it possible? |
Sun, May 26, 2013 at 1:42:59 PM
Importing views from other revit projects |
Tue, May 26, 2009 at 6:48:12 AM
Members: | 2100177 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
