95 Users Online (94 Members):
Forums >> Revit Structure >> Technical Support >> SHOW PRIMARY & SECONDARY BEAMS WITH DIFFERENT LINEWEIGHTS ON A SECTION
HI THERE I HAVE A SECTION THAT CUTS THROUGH SOME PRIMARY AND SECONDARY BEAMS. I WANT TO SHOW THEM IN A DIFFERENT LINEWEIGHT BUT GOING INTO THE GRAPHICS OVERRIDE WILL NOT LET ME DO SO. I CAN CHANGE LINEWEIGHTS AND COLOURS FOR ALL OF THE FRAMING ELEMENTS, BUT IF I CHANGE THE LINEWEIGHT OR COLOUR FOR JUST PRIMARY BEAMS IT DOESN'T SEEM TO WORK. IS IT POSSIBLE TO SHOW PRIMARY & SECONDARY BEAMS DIFFERENTLY ON A SECTION?
2 Posts No Rating |
You could use the linework tool to override in the section view - I'm sure there's an easier solutions - but that's all that I can see. M.
![nastyclown Avatar](user_avatar/114560.jpg)
![4.5 Stars: 9 Votes](/images/stars_4.5.gif) |
you can override by element... i hope there is no tons of beams there, couse its going to take forever.
over-ride by element is the only way i have found to do it. This for me is one of the big problems with revit, that it is not customisable enough. For example: in a section all structural framing elements are by default shown with the same lineweight. The ISO standards say that an r.c. beam in section should be shown with a much thicker line than an steel beam in section. on a plan the standard that we use at my company says that an existing steel beam should be shown as a much thinner line than a new steel beam (we fudged this by making existing beams 'primary' and new beams 'tertiary' and changing the way each prints out on plan) has anyone found a way of putting different beams on different 'layers' an being able to make all elements on a certain layer print out in a particular way in plan and in section? Thanks for your help
If you had the patience, you could modify the family and add a sub-category. Assign an instance parameter primary/secondary and turn on/off elements in main category vs sub-category. This would work and might be worthwhile.
How to globally adjust Revit lineweights in section |
Wed, Aug 20, 2014 at 8:36:09 AM
3D View of Primary Design Option AND Secondary Option Together |
Thu, Feb 22, 2007 at 1:53:40 PM
Design Options |
Tue, Oct 3, 2006 at 9:49:08 AM
Issue with making a not primary option the primary Design Options Revit 9.0 |
Wed, Jun 4, 2008 at 5:52:15 PM
Revit lineweights |
Wed, Jan 28, 2015 at 9:31:49 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
