84 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> REVIT CONTENT - problem with velux family
Wed, Nov 10, 2010 at 3:26:56 AM | REVIT CONTENT - problem with velux family
JeroentjeM
Hello,
yesterday I've purchased the Velux family form "revit-content.com". Now as you can see in the added image, I'm having problems with the views in a project. 3d and section are fine, but the floorplans show strange things.
The floorplan in which the window is, should display a dashed line or something, I will add this myself, but how do I make all the other lines dissapear from this view?
And in the second floor plan, I would expect just to see the Velux from top, but instead the complete Velux is hidden, and only the roof cut is shown.
Help! Smile Any ideas?  Thanks in advance.
Wed, Nov 10, 2010 at 5:22:24 AM | REVIT CONTENT - problem with velux family
aspect
I would try an open up the Velux Component ('Edit Family' tool), then have a look at the visibility setting in the Views>Floor Plans>Ref Level area. If you click a component then go to 'View>Visibility/Graphics' you should be able to change settings for how the componets shows up when its in your model. Sometimes if the family component with the is complex you might also need to edit the component within the component )if you know what I mean) and check the visibility settings the same way as above.
Good Luck
www.aspectarch.com
Wed, Nov 10, 2010 at 7:40:35 AM | REVIT CONTENT - problem with velux family
Just hide the unit in the plan view... draw your dashed lines first.
No light through Velux Windows
Wed, Mar 13, 2013 at 9:51:29 AM
Velux Window in Roof Slope
Thu, Jun 4, 2009 at 4:12:05 PM
Revit Family Content
Mon, Jun 3, 2019 at 3:14:22 PM
Revit Users and Content
Wed, May 11, 2016 at 8:57:39 AM
Revit Content
Fri, Jun 17, 2005 at 2:40:36 AM
Page generation time: 2.2643
