Forums >> Revit Building >> Technical Support >> sloped ceilings?
28 Posts No Rating |
Is it possible to do angled ceilings?
You can only create "Sloped Ceilings" by "Model In-Place" method, go to Home > Component > Model In-Place then choose the category Ceiling and use the tools you have there (Solid Extrusion, revolve, sweep, swept blend..) to create your ceiling like you want.
I could be wrong, but I am pretty sure you can slope a ceiling and not have to model it in place. I remember doing it in Revit 9.1 and I do not see any reason they would have got rid of it. I do not have RAC on my computer only RST so I can not check this to be sure how it is in 2011 or which ever version you are using, but there used to be two ways to make a ceiling, sketch and picking. If you sketch it you should be able to click on the pink lines just as you do with a floor or roof and assign it a slope. There is a checkbox up at the top of the screen that should say "Slope" to allow you to assign a slope to the line.
Edited on: Wed, Nov 10, 2010 at 10:30:04 AM
My mistaque, of course you can use the slope arrow to create a slope in your ceiling like you can do that in floors/slabs, i was thinking not in that but in this kind of ceilings: http://www.revitcity.com/forums.php?action=viewthread&thread_id=21697
Sloped Ceilings |
Thu, Jan 23, 2014 at 4:54:40 PM
14
Slanted wall in section & sloped ceilings |
Wed, Feb 18, 2009 at 2:10:44 PM
Ceiling Heights Scheduled - Problem: Sloped Ceilings |
Wed, Jan 13, 2010 at 9:28:49 AM
Lights and Sloped Ceilings |
Mon, Feb 14, 2011 at 4:47:18 PM
Recessed Lights in Sloped Ceiling |
Thu, Dec 13, 2007 at 10:23:28 AM
Members: | 2101676 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
