65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> odd box look at curtain walls
Wed, Oct 26, 2005 at 8:36:26 AM | odd box look at curtain walls
latemore
latemore Avatar
3 Stars: 2 Votes
we are beginning to use curtain walls, and have practiced a little in revit's own template, but when we draw a curtain wall in our own template file, it has these odd looking boxed grid patterns sitting to one side. i cannot find any global setting that might relate to this. does anybody have a clue why it looks wierd please? have attached a screen shot.
Wed, Oct 26, 2005 at 6:06:50 PM | RE: odd box look at curtain walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Latemore, Looks fine to me... As you can see with the system panel in the template the glazing is shown rediculously thick and also offset from the centre of the curtain grid, so you may wish to adjust the system panel settings: In the project browser-->Families-->Curtain wall Panels As the grids to the curtain wall are actually planes they always show extended when selected as you show in your pic... HTH.
Wed, Oct 26, 2005 at 6:13:22 PM | RE: odd box look at curtain walls
latemore
latemore Avatar
3 Stars: 2 Votes
thanks mr spot i knew i could count on the master to help. i will look into what you suggest. because of your many comments on revitcity about curtain walls, we really want to learn how to use their power.
Thu, Oct 27, 2005 at 6:21:15 AM | RE: odd box look at curtain walls
latemore
latemore Avatar
3 Stars: 2 Votes
hi mr spot i may have found what you referred to - in curtain systems there is an offset field, which for some reason was set at 100mm. i changed it to 0, and the weird look dissappeared. thanks for you help. will need to study curtain walls a lot!
Revit 2014: Curtain walls at corners
Tue, Aug 12, 2014 at 10:10:28 AM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Urgent Help for Operable Curtain Walls
Mon, Oct 18, 2010 at 12:30:25 AM
ACA Curtain Walls vs. Revit
Sun, May 4, 2008 at 8:20:27 PM
Page generation time: 1.2553
