52 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Beam Tag with Top of Steel Elevation ?
23 Posts No Rating |
Anyone know of a combined Structural Framing Tag that will show the beam type and it's elevation? See attached for image of how I'm using a standard framing tag with a modified spot elevation, to look like one tag. I can live with using Revit's standard Structural Framing Tag and a spot elevation for both ends of sloped beams, but it'd be great to have a combo-tag for all the horizontal/level beams. Revit Architecture 2011
I do not belive there is a way to do this other than how you are doing it. There is nothing tagable in the system family or a parameter in the tag that associates the beam with a paticular elevation.
49 Posts No Rating |
In revit Structure, there is a way to do this. ANNOTATE menu->TAG->BEAM ANNOTATIONS.
Not sure about Revit Arch.
97 Posts No Rating |
Try this tag out. Seems to work just fine.
3 Posts No Rating |
Thank you.
flat channel top of steel |
Wed, Oct 26, 2011 at 2:13:55 PM
Quickly See Beam Top of Steel Elevation |
Thu, Oct 16, 2014 at 10:51:52 AM
Steel beam views |
Fri, Apr 1, 2016 at 3:08:27 PM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Top of Steel / Bottom of Deck Elevation using a Spot Elevation? |
Fri, Jan 21, 2011 at 2:04:46 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
