46 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Floor Slab not visible in Plan!
![crwinchester Avatar](user_avatar/187252.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
For some reason I can't see my floor slab in a plan view. The category is visible in the graphic settings; the cut plane shows everything below or above the slab, but not the slab itself; its visible in 3D (of course) but the strange thing is that the slab is visible when the 3D view is oriented to the plan. I feel like I've traversed all the usual suspects in the settings, graphics, and object parameters. Any suggestions? Thanks!
Check the lightbulb - it could be hidden in view. Are you messing around with phases?
Duh. Thanks for the lending another set of eyes! BTW, Did I message you about my sloping wall issue? Thanks again!
Stair visible through floor |
Thu, Feb 5, 2009 at 5:21:21 PM
Displaying different floor types |
Thu, Feb 2, 2006 at 9:35:53 AM
Showing walls from the bottom of slab |
Tue, Feb 9, 2010 at 10:40:40 AM
drawing lines over a tike floor |
Mon, Mar 30, 2009 at 5:21:15 PM
walls not visible on floor plan |
Thu, May 13, 2010 at 7:20:15 AM
Members: | 2017311 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
