47 Users Online (46 Members):
Forums >> Revit Structure >> Technical Support >> Sloped joist line type
10 Posts No Rating |
I'm new to revit and I'm having trouble when a joist is sloped. The clouded joist in the attached pdf is not sloped and it appears with the correct line type that I assigned to it. If I slope the one end of the joist to 6-1/2" (which is what the joist needs to be sloped at) the line type of the joist changes to a large dashed line type as shown in the attachment. My cut line in the view range is 2' above the joists and the bottom of the view range is 4' below the bottom of the joist. Why is the line type changing when the joist is sloped?
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Did you say the line-type was changing? That's usually a sign of a glitch in the matrix.
Joist Seats on sloped joists |
Wed, Oct 24, 2012 at 1:27:46 PM
13
Joist sitting on Sloped beams |
Wed, May 28, 2008 at 8:09:37 PM
Sloped Structural Joist |
Mon, Nov 7, 2005 at 12:14:32 PM
Sloped joist seat |
Wed, Oct 24, 2012 at 1:26:11 PM
Double Sloped Steel Joist |
Thu, Dec 23, 2010 at 8:35:13 AM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
