99 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Nested Door Families and Door Schedules
Mon, Nov 8, 2010 at 2:42:26 PM | Nested Door Families and Door Schedules
dmbranch
dmbranch Avatar
I have been racking my brain trying to figure out what I am doing wrong with this and I need someone's help please!I have created a series of hollow metal door frames for a commercial project that I am working on. In addtion to that I have created a series of door panels that I am nesting into each door frame. I have set the visibility for (yes/no) on each door panel inserted into the various hollow metal door frames.I have setup a sample project and tested the family and the doors turn on an off as it should. I have also made sure that each door slab that I created has the shared parameter value checked.When I start adding doors it will skip door numbers. What it is doing is counting the frame as a door and the door type nested that is visible as a door type. So when I create my door schedule it schedules my door slab separate from my frame type.What in the heck am I doing wrong?Please help
Mon, Nov 8, 2010 at 2:48:40 PM | Nested Door Families and Door Schedules
Revit is reporting exactly what you are supplying I think.  If your door leaf is a door and your door frame is a door...well - that's two doors.
I personally don't like nested families in this instance but if the nested family is a different type, you can get this to work.
Mon, Nov 8, 2010 at 2:51:53 PM | Nested Door Families and Door Schedules
dmbranch
dmbranch Avatar
I agree with you 100% WWHub.  I tried making the door slab just a generic model and then still sharing the custom parameters that I need.  That works with the door numbering problem, but then I lose the custom parameters that I have assigned to the door slabs.  Any suggestions on that?
Thanks for the advice.
Mon, Nov 8, 2010 at 2:56:47 PM | Nested Door Families and Door Schedules
If you have the needed parameters in the host family, they can be linked to the nested.  ie:  Host param (Door Material) passed to hosted familf (Door Material)
Schedules - Nested Families not showing up
Mon, May 25, 2009 at 12:11:14 PM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:25 PM
Controlling visibility of nested families in familes with multiple types
Mon, Jan 6, 2014 at 10:37:46 PM
Nested families stored in project - Not in family
Mon, Jun 20, 2011 at 4:21:13 PM
Nested Door family
Thu, May 31, 2007 at 4:36:52 PM
Page generation time: 2.3962
