37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
Mon, Nov 8, 2010 at 6:25:10 AM | BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
Daveybdab
I HAVE SOME STEEL BEAMS THAT ARE PRINTING OUT AS SOLID LINES RATHER THAN THE CHAIN DOT LINE I HAVE SPECIFIED. SOME OF MY BEAMS PRINT OUT FINE BUT OTHERS DO NOT. THE ONES PRINTING OUT AS A CONTINUOUS LINE ARE UNDERNEATH SOME FLOOR STRUCTURES THAT ARE AT A HIGHER LEVEL. ON THE SCREEN ALL LINES LOOK OK, BUT NOT WHEN I PRINT OUT. ANY IDEAS?
Mon, Nov 8, 2010 at 12:10:23 PM | BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
rkitect
rkitect Avatar
4 Stars: 29 Votes
Try printing as a PDF or exporting a DWF.  Do they come out as continuous then also?  If not, try printing the PDF/DWF.
Weird printing bugs strike again!
Mon, Sep 8, 2014 at 12:05:48 PM | BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
Balitog
Printing does not change the rendering of the beams from preview
Mon, Sep 8, 2014 at 12:26:44 PM | BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
Are you complaining about lines in plan view?
If so, then look at what lines you have set for this.  If the scale is too small and the line is too short to show as perscribed, you will see a solid line.  Change the line style in this view for those objects.
transparent object in coarse view
Mon, Nov 8, 2010 at 12:00:42 PM
Stick representation of beams
Tue, Mar 3, 2009 at 11:47:07 AM
Visual Style of Beams in Plan View
Thu, May 22, 2014 at 4:01:04 PM
Beams in 3D view shows only one line, not the whole volume !
Mon, Sep 8, 2014 at 12:13:25 PM
How to see the upper floor (beams,floors) in plan view?
Tue, Jun 14, 2005 at 4:37:21 AM
Page generation time: 1.0918
