65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
Sat, Nov 6, 2010 at 8:09:12 AM | LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
Daveybdab
Is there any way to increase the number of characters that will appear in the beam/ column schedules under type? i have some beam that require quite a detailed description and the end of it is being cut off in the beam schedules.
thanks for your help
Sat, Nov 6, 2010 at 8:17:45 AM | LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
dmahan
you can drag column width to adjust, both in the schedule view and after schedule is placed on sheet
Sat, Nov 6, 2010 at 8:25:58 AM | LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
Daveybdab
unfortunately my text is so long that even moving these wont desplay all my text.
Sat, Nov 6, 2010 at 8:37:23 AM | LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
add the specification of that in an anotative view.... you can tag a code in the type, so later you reffer to that code in that detail view.
Detail Components and How to Schedule them
Mon, Jul 6, 2015 at 9:32:44 AM
13
Creating a Beam Family Where Each Type has a Determined Length
Wed, Aug 31, 2016 at 11:55:27 AM
11
Beam System Visibility
Wed, Mar 22, 2006 at 9:23:08 AM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:08 PM
sloping beam system?
Thu, Apr 20, 2006 at 4:56:36 PM
Page generation time: 1.3820
