96 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Wrapping a wall type at bottom of wall
4 Posts No Rating |
In a revit model, I have an exterior beam wrap (at front porch) that I created as a wall type. It's basically 5 1/2" wood studs with 1/2" plywood sheathing and 1/2" finish trim on each side. Is there any way to wrap the bottom side of the wall (or the beam wrap in this case) with the sheathing and trim to close off the bottom side? You can wrap the inserts and ends in Edit Assembly, but I don't see a way to wrap the top or bottom surfaces. Thanks.
Unfortunately wrapping top and bottom is severely lacking in Revit. You may want to try split surface tool combined with paint to get the desired results.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:08 PM
wall wrapping problems |
Wed, Mar 4, 2015 at 9:59:02 AM
Brick will not wrap to new wall type |
Thu, Apr 28, 2011 at 10:18:56 AM
wrapping wall materials |
Thu, Aug 14, 2008 at 4:40:22 PM
Wall wrapping |
Thu, Aug 30, 2007 at 10:19:20 AM
Members: | 2057551 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
