59 Users Online (58 Members):
Forums >> Community >> Newbies >> printing to scale
10 Posts No Rating |
I have read the documentation I have looked at tutorials etc. What I want to do is print to scale without a title block. Thanks
You want the scale in the titleblock of the sheet? Obviously a sheet can have many views, all with different scales, so Revit has no way of knowing which one to pick. If you want this, add a parameter to your titleblock that you fill in. Or, create multiple titleblocks, each with a different scale shown and you pick the correct one when you need it.
![3 Stars: 2 Votes](/images/stars_3.gif) |
You cant really do this...the way that I got around it was to create a blank title block at the paper size you want to print on...ie create a 8.5x11 "Title Block" that only has the 4 lines that create the rectangle shape of 8.5x11 then place the view on that and print it. Printing to scale and not using a title block can't really be done that I am aware of.
![4 Stars: 7 Votes](/images/stars_4.gif) |
Do you mean printing a view without placing it on a sheet? If so, just send it to the plotter as you normally would. Don't use Fit to Page in settings, and set the Zoom to 100%. That's what I've been doing, and it works fine.
Kennedy, How do you know what your going to get though? That has always been my issue. If I just need a portion of a plan on 8.5x11 to scale I could never get it to print the area I wanted without placing it on a sheet.
gdoherty0102, If you want to print just a portion of a view that is 1/4" scale at 1/2" scale - then change the view scale, move the view crops, print the view and undo all your changes.
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale. |
Tue, Sep 6, 2011 at 7:51:06 AM
Printing |
Tue, Oct 5, 2010 at 6:38:41 PM
Printing views to scale? |
Fri, Aug 31, 2007 at 8:33:25 AM
Printing an A1 sheet |
Mon, Mar 18, 2013 at 3:21:14 PM
printing in revit |
Thu, Oct 22, 2009 at 10:26:33 AM
Members: | 2022542 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
