84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to type degree symbol in text
Tue, Oct 25, 2005 at 8:57:11 PM | how to type degree symbol in text
mino
HI I would like to know that how to type degree symbol in text when you are set up a working drawing. E.g. like 25 dregee ( symbol) pitch Hope you can answer me soon
Tue, Oct 25, 2005 at 9:41:31 PM | RE: how to type degree symbol in text
Priority
1 Hold down the "Alt" on your keyboard 2. Use the number pad on your keyboard and type 0176 I think that will do it Post edited on 2005-10-25 21:41:57
Tue, Oct 25, 2005 at 9:49:12 PM | RE: how to type degree symbol in text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Its actually Alt 0186... �
Wed, Oct 26, 2005 at 8:56:31 AM | RE: how to type degree symbol in text
jstewart
I use Alt 248
Wed, Oct 26, 2005 at 5:54:49 PM | RE: how to type degree symbol in text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well that works too... didn't know about that one. All these key shortcuts can be found in the windows character map if you ever need to do other symbols: � Alt 0216 is diameter � Alt 0178 is squared � Alt 0179 is cubed for some of the common ones...
Sun, Mar 18, 2007 at 3:52:15 PM | how to type degree symbol in text
birdie
ok, so holding alt followed by appropriate number doesn't work on my laptop. what next?  i desprately need the degree symbol.
Sun, Mar 18, 2007 at 6:26:22 PM | how to type degree symbol in text
framerman
4 Stars: 13 Votes
well, the proper degree symbol is alt+0176 in most cases. The others are theta symbols, ordinal indicators, small 0's with lines through them, etc,
really the only way to do it is to go to the character map located at start>all programs>accessories>system tools and check it yourself under the correct font that you are using in your project. Sometimes they change according to font. If you have a unique font, this could be the case why it isn't going through.
After you have found it you can either copy and paste it, or type the alt+ number. as soon as you release the alt key, it should appear for you.
Sun, Mar 18, 2007 at 10:22:01 PM | how to type degree symbol in text
TomDorner
4.5 Stars: 25 Votes
Just to clarify for laptop users, the ALT+ method will only work if you have a seperate number section of a keyboard.  Same thing goes for standard keyboard users, you need to make sure to use the Numbers Keypad not the numbers above the letters.
You can also simply use MS Word to insert charachters and copy/paste into Revit text.
You can also get to the charmap by going to Windows Start>Run>charmap
I include these special characters in a drafting view that is part of our template.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Mar 19, 2007 at 11:45:36 AM | how to type degree symbol in text
finale
another way to access the character map is to >start>run type "charmap"
Mon, May 21, 2007 at 11:36:24 AM | how to type degree symbol in text
rgesner
Many laptops have a numeric keypad overlaid on the righthand side of the keyboard, which you access with the Function key, so to enter special characters, you'd hold down both the Function and Alt keys while typing the numeric key code.
B. Rustin (Rusty) Gesner, IT/CAD/BIM Director, Mackenzie, Portland, Oregon - Architecture, Interiors, Structural, Planning, Civil, Landscape, Traffic & Project Management
Mon, May 21, 2007 at 11:54:30 AM | how to type degree symbol in text
#11
TJKENNEDY
3 Stars: 2 Votes
Large list of Alt codeshttp://en.wikipedia.org/wiki/Windows_Alt_keycodes
how to type degree symbol in latex?
Sun, Sep 8, 2019 at 12:22:16 PM
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:35 PM
22
Symbol Text
Thu, Dec 10, 2009 at 5:39:09 PM
Symbols
Fri, Nov 25, 2005 at 5:20:56 PM
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:21 PM
Page generation time: 1.9461
