49 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Read nested parameter value - extract nested value
86 Posts No Rating |
Hello, in my window family I use several nested windows, which all can have varies glass surfaces, depending on their size. I made an parameter inside this nested familys, whis works. Except in my main window, can I read out these values? So I can use them for a total count of glass in the main window? Hope someone understands my question, and even better, has the solution? Thanks!
Edited on: Thu, Nov 4, 2010 at 3:35:03 AM
Open that "Nested Family", in "Family category and parameters" you have a "Share" option, turn that ON, now load into the main window.
Typhoon, thanks for the reply. Doing this results in the attached announcement. I guess wanna hev both of these functionality's is not possible? Reason that I want this, is because there's an option to select "panel", so then I could set the "glass surface" of this nested panel to zero, so this one would be ignored in the total glass surface of the main window. But after reading some other posts over here, guess this can't be done...?
Pulling System Parameter From Nested Family |
Wed, Jan 9, 2019 at 8:58:25 AM
Nested Families and System Parameters |
Fri, May 8, 2015 at 9:47:41 AM
Level parameter value of nested families in project. |
Fri, Dec 13, 2013 at 4:09:17 AM
nested family visibility parameter |
Sat, Jan 19, 2013 at 7:34:32 AM
scale nested family within a family (2017) |
Wed, May 3, 2017 at 5:28:43 PM
Members: | 2022300 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
