49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stair questions... Revit 2010
Wed, Nov 3, 2010 at 2:19:07 PM | Stair questions... Revit 2010
arusso5
Hey, I'm having an issue with stair graphics and can't seem to find the answer here on the forums.  I am working on an existing building renovation.  We have an existing stair which we are not touching.  This stair goes from the first floor two flights up to the mezzanine level.  When we set the stair to the 'existing' phase, the stairs above the cutplane become solid lines (which we don't want).  The other 2 stairs that we have have stairs that go up from the first floor and down from the first floor.  If I use VG to uncheck the stairs above and stringers above cut line, my existing stair is also affected.
Is there anyway to have the existing stair show the stairs above the cutline as <overhead> while the new construction stairs show up and down?  Seems like this should be a common occurrance.
Thanks.
Tue, Nov 30, 2010 at 3:06:22 PM | Stair questions... Revit 2010
cadman7577
1 Stars: 1 Votes
Well I have a similar issue.  First level stair is seen through the second level plan.  However the stair going to the thrid level is not seen (which I want).  I have checked all the settings and feel like the second and third levels have the same settins (according to their level) but this issue does not go away.
Wed, Jul 13, 2011 at 12:16:08 PM | Stair questions... Revit 2010
JUGRNOT
What about adjusting the clipping plane?
Wed, Jul 13, 2011 at 12:23:40 PM | Stair questions... Revit 2010
cadman7577
1 Stars: 1 Votes
I have tried that.  I have started simply applying a filter to one of the stairs.  Works great.
Upgrading from revit 2010 to 2012
Thu, Oct 27, 2011 at 7:19:25 AM
Newbie revit questions- stairs with landings?
Tue, Oct 2, 2007 at 2:02:38 PM
noob with questions and some experience
Sun, Oct 4, 2009 at 5:21:39 AM
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:16 AM
Floating Tread Stair
Mon, Nov 6, 2017 at 5:17:59 PM
Page generation time: 2.0397
