76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof overlap
Wed, Nov 3, 2010 at 12:57:20 PM | Roof overlap
passell
I have a sloped roof interrupted by a wall. It is an offset gable, so one plane of the roof is continuous and the opposite slope of the roof is interrupted by the wall. The lower roof stops at the edge of the upper roof overhang instead of extending to the wall. Should I create the roofs separately and then join them, or is there an easier fix?
Tue, Nov 9, 2010 at 8:25:44 AM | Roof overlap
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Yes you will probably have to use two roof in this situation.
New to revit, overlap visibility problem
Wed, Sep 4, 2013 at 12:12:24 PM
temporary dimensions overlap
Wed, Apr 15, 2015 at 1:31:30 PM
Roof Joins for crickets on roof
Tue, Jan 12, 2010 at 2:36:03 PM
3D Roof Tiles for temple
Sat, May 15, 2010 at 6:55:42 AM
custom material
Mon, Jun 25, 2007 at 6:31:59 AM
Page generation time: 0.3978
