69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall sweeps ignore room boundaries
Wed, Nov 3, 2010 at 9:50:03 AM | Wall sweeps ignore room boundaries
aneglia
In elevation view, I have placed a wall sweep (a wood base) on a wall.  It looks fine, except that the sweep continues right through to the room adjacent and ignores the wall separating the two rooms.  The wall the sweep is on is a generic 1' 10" wall that is continuous from room to room.  The wall separating one room from another is a generic 5" wall.  What am I doing wrong with either creating the wall sweep or the walls?  I am thinking that it must have to do with the fact that the 1' 10" wall is continuous, but it seems silly to break up this exterior wall every time it intersects an interior partion wall just so the wall sweeps will terminate as they should.
 Any advice?
Wed, Nov 3, 2010 at 10:30:52 AM | Wall sweeps ignore room boundaries
lunchtrayrider
3.5 Stars: 7 Votes
you are correct on all points.  you can drag the ends of the sweep around and add more if you like, then you wouldn't have to split the wall.
I like scooters. and motorcycles.
editing room boundaries [ 1 2 ]
Thu, Oct 5, 2017 at 7:21:20 AM
17
Revit 2012 - Edit Room Boundaries
Tue, Jul 5, 2016 at 2:42:17 PM
11
Room boundaries woun't properly display
Tue, May 15, 2018 at 3:08:15 AM
Any way to automaticaly find room boundaries to make finishing floor?
Wed, Sep 17, 2014 at 8:13:12 AM
room boundaries
Mon, Jun 4, 2007 at 2:42:09 PM
Page generation time: 2.2771
