Forums >> Revit Building >> Technical Support >> Glass Structural Floor...PLEASE HELP ME
5 Posts No Rating |
I'm trying to create a glass structural floor with mullions on portions of a floor. Any suggestions? I've tried several ways and I've failed...Here is and example of what I want. Thank you in advance
You can use the "Roof > Sloped Glazing" System, check in your HELP menu...
You could do as ty suggests but I would model as a glass floor then add an in-place extrusion that is the grid of the structure and that family would be assigned to the floor category.
5 Posts No Rating |
Thank you both...How do you model as glass floor...I'm kinda new to Revit, Model in place? Massing?
If you are doing it my way, you create a floor and assign the thickness to the thickness of your glass and assign glass as the material. The structure would be an in-place family. If you are doing it typhoon's way, follow the HELP as ty suggested.
5 Posts No Rating |
Thanks a lot :D...I'll post the results soon
thats unreal, the reference image you showed here is the company i used to work for as a part 1 architect! what are the chances of that haha
making glass floor in revit 2009? |
Sun, Mar 15, 2009 at 3:35:00 AM
RAC 2010 Structural Floor V Floor - Whats the difference |
Tue, Jul 27, 2010 at 8:35:33 AM
Different between Structural Floor and Floor |
Fri, Dec 10, 2010 at 4:47:12 AM
how to make beams from a mass model, and how to add a floor to it |
Sun, Oct 22, 2017 at 1:10:11 PM
Copying Structural Framing to Other Floor. |
Mon, May 11, 2015 at 11:32:27 AM
Members: | 2098018 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
