Forums >> General Discussion >> Wishlist >> STAIRS - Stringer & Handrail Cut
Mon, Nov 1, 2010 at 8:06:54 PM | STAIRS - Stringer & Handrail Cut
CADDAN
I would like to see the addition of a square cut for both the stringer & handrail detail to allow a seamless connection to adjoing elements.
Stringers currently cut on the vertical which means landing connections over hang if the same sized timber is used.
Similarly with handrails no setting exists to terminate with a parallel cut.
See attached.
Choppy Handrail / stringer joints
Wed, Mar 25, 2009 at 11:00:25 AM
Stair Stringer connections
Wed, Jan 14, 2015 at 11:14:39 AM
Handrail Supports on Multistory Stairs
Tue, Jun 24, 2014 at 3:10:16 PM
Revit 2012 Stairs & Handrails
Mon, Mar 18, 2013 at 7:44:25 AM
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Page generation time: 0.6534
