47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Analytical question
Mon, Nov 1, 2010 at 12:04:46 PM | Analytical question
ESCOZA
5 Stars: 2 Votes
Has anyone tried to export a revit model to an FEA Analysis program such as Ansys before? If so how do you get reinforcing bar to appear in the transferred mmodel?
Mon, Nov 1, 2010 at 4:14:10 PM | Analytical question
gdoherty0102
3 Stars: 2 Votes
I am not framiliar with FEA Analysis programs, but two things you may look at to see are: 1) Was the rebar created with the "Area" or "Path" tool for rebar?  If they are, that could be why they wont export. 2) Go into a 3D view...select all the rebar and make sure that it is shown extruded in the 3D view, then export out using that 3D view, from what I remember the rebar has to be extruded in the view to export out correctly.
HTH
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:30 AM
Analytical Modeling Issues
Wed, May 14, 2008 at 12:03:14 PM
Analytical Line
Tue, May 23, 2006 at 6:00:18 AM
Deactivate Analytical Truss and Slab
Wed, Feb 9, 2011 at 8:10:56 AM
Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 8:10:30 AM
Page generation time: 27.1938
