67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Titleblocks
Mon, Nov 1, 2010 at 6:59:16 AM | Titleblocks
iksnawi
Looking to be able to have editable text parameter in a titleblock that is a sub catagory to the sheet title. So each sheet can be different than the next but editable in the browser.
thanks
Mon, Nov 1, 2010 at 7:24:34 AM | Titleblocks
If you mean you want something that will allow you to call two sheets "Same Name" because you have a second field of dat, you will not be able to do that.
You can have a sheet "One name" and another sheet "different name" and have another parameter assigned to sheets that can be edited from the browser but it will not be part of the sheet name.
You can also assign a parameter to a sheet that can be part of your browser organization and you could use it in browser sorting.
TitleBlocks
Fri, Dec 8, 2006 at 8:08:03 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:34 PM
Labels in Titleblocks?
Mon, Nov 10, 2008 at 3:30:02 PM
Titleblocks
Mon, Mar 17, 2008 at 3:03:11 PM
Multiline text on Titleblocks
Sun, Oct 5, 2008 at 8:17:14 PM
Page generation time: 2.5580
