94 Users Online (92 Members):
Forums >> Revit Structure >> Technical Support >> slanted model in place column
Hi there. i have some cranked columns taht i have modeled in place (i swept them along a cranked path). Is there any way i can make it so that the angled part of the colmn (which is at about 45 degrees) shows on my plan as a beam symbol (i.e. chain dotted line) rather than a elevation of the actual column.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Visibility Graphics, Graphics Override? If it is an in place component (as opposed to an in place mass) you can set the mass to a subcategory of the Beam category and change the graphics of that subcategory in your Object Styles dialog. See if any of this gets you going in the right direction.
Slanted Columns in Revit LT ?? |
Wed, Mar 13, 2013 at 8:28:19 AM
Trim on slanted column |
Mon, Sep 8, 2008 at 1:20:01 PM
Mirroring a slanted column |
Mon, Mar 10, 2014 at 7:50:04 PM
Can't mirror L Angle slanted column |
Mon, Apr 11, 2011 at 9:52:21 AM
Slanted column |
Sat, Nov 5, 2005 at 9:44:09 PM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
