87 Users Online (85 Members):
Forums >> Revit Building >> Technical Support >> formula using <Family type> parameter
86 Posts No Rating |
Hello, A formula using a familytype parameter is not possible. Any workaround for this? I have a window family of which I'd like to calculate the total glass area. The window can be up to 7 parts wide. Problem is that users can also choose a nested family which represents a panel, so when this choice is made, the "glass-area" of this part should be ignored... Thanks!
![nastyclown Avatar](user_avatar/114560.jpg)
![4.5 Stars: 9 Votes](/images/stars_4.5.gif) |
It is possible, you just need to specify the "area" or "volume" when you are creating the parameter from the type editor inside the family. Heres an example, just change the length, height and depth (L, H and D) and your volume will change.
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Including different formula parameter for each type? |
Wed, Sep 5, 2012 at 1:18:28 PM
parameter formula to read the type name/family name |
Tue, Jul 9, 2013 at 8:34:04 AM
Formula for Manhole Family |
Fri, Oct 5, 2012 at 11:18:05 AM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
