81 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Slab Edge
11 Posts No Rating |
I'm using Revit 2011. I have about 15 Floors and there are two floors that have a different thickness for the slab the problem that I am having when I try to change the profile assigned to the floors with different thickness, the other floors change. The profiles do not have parameters, they are two seperate files. Can anyone help me figure out why this happens? Thanks
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Remember, you have two different things to set up with a sweep type object, the profile and the sweep type. Your issue is that you are redefining the sweep type that is applied to all edges. You need to duplicate and make a new type for each profile.
Thanks! Worked like magic
"Could not create Slab Edge" |
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab |
Thu, Jul 14, 2011 at 11:04:56 AM
Revit 2010 Slab Edge Trouble |
Mon, Feb 15, 2010 at 8:54:39 AM
Slab edge profile not available |
Tue, Nov 10, 2009 at 1:56:29 PM
Creating slab edge... |
Tue, Nov 4, 2008 at 3:36:02 PM
Members: | 2022449 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
