Forums >> Revit Building >> Technical Support >> In place mass - rotating itself
Hi, I’ve created a load of in place masses to represent buildings around Revit model. I’ve move and rotated the in place masses into the correct position. But strangely, when I click on them and select ‘Edit In-Place’ they immediately flip around to another seemingly arbitrary rotation, and when I select finish they flip back. Why is this happening, I need to change the mass shape by tracing some lines, but can’t do this when they rotate themselves. Cheers.
Anyone? This seems odd to me - I can't believe its by design...
I have had this problem as well - it seems to be because you moved and/or rotated it after you finished editing it. When you open-edit the mass it reverts to the original orientation. It will probably be easier to make a new mass with the proper orientation and once you've finished it don't rotate it outside of edit mode.
Thanks for your reply. This is actually really annoying, if your've editted your model some as redoing it takes time. It seems like a bug to me. Cheers.
11 Posts No Rating |
I was having a similar problem. Thanks for the heads up.
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw |
Sweeping Solid In-Place Mass |
Tue, Apr 27, 2010 at 3:30:39 AM
Conceptual Mass rotating on its own.. possibly possessed Revit Program? lol |
Tue, Nov 13, 2018 at 3:11:04 PM
In-Place Mass Wirefram |
Fri, Jan 11, 2013 at 8:47:33 AM
Rotating a mass in family |
Fri, Aug 11, 2006 at 2:11:15 PM
Issue creating mass floor area schedule (mix of families & 'model in place' mass |
Thu, Sep 27, 2012 at 7:05:37 AM
Members: | 2100928 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
