80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Load Family button does not pull open the file browser
Wed, Oct 27, 2010 at 7:36:44 PM | Load Family button does not pull open the file browser
jessbraker
I haven't been able to use the load family button because there is no apparent activity when I hit the load family button.  When it was working it would open a file browser so that I could locate the family to be loaded.
Thu, Oct 28, 2010 at 6:45:27 AM | Load Family button does not pull open the file browser
Are you in a view that you could use the family in?
Do you have the path to your library set?  (Revit R - Options )(Possible corrupted ini?)
Thu, Oct 28, 2010 at 7:45:15 AM | Load Family button does not pull open the file browser
jessbraker
No, No, and I don't know how to check for a corrupt .ini.  The bar grays out, but the file browser does not pop up.  I have to exit out of it, but am not able to use it.
Thu, Oct 28, 2010 at 7:55:54 AM | Load Family button does not pull open the file browser
Please look again at my post:  I also said:  "Do you have the path to your library set?  (Revit R - Options )"  Look at the file locations set there.... The library path has to b e set and the library has to be where this points to.  If you are on a network, and the library is on the network... are you connected?
Thu, Oct 28, 2010 at 8:21:13 AM | Load Family button does not pull open the file browser
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
It sounds like you are talking about the dialog box for loading files. Do you have multiple monitors? Is it hidden off the screen?
Try minimizing your revit when you click on the button to see if it shows up behind the program.
Thu, Oct 28, 2010 at 8:46:47 AM | Load Family button does not pull open the file browser
jessbraker
Ok, I tried to path the library to the network location and my local location as a test, same result.  I do have multiple monitors?  I haven't found the box yet, but will let you know as I keep trying (Revit locked up when I made it 1/2 screen.
Thu, Oct 28, 2010 at 9:24:43 AM | Load Family button does not pull open the file browser
TKennedy
4 Stars: 7 Votes
To check if your window is off screen: click the load family button so you should have the dialogue box open. Press Alt + Space, then M. Your cursor should now be the move cursor. Hit any of the arrow keys, and the window should lock to your cursor, so you can drag it to where ever you want it.
Wed, May 4, 2011 at 12:51:04 PM | Load Family button does not pull open the file browser
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Did anyone solve this? I have the same problem and the window is no where to be found...libraries are set to the default location.
Wed, May 4, 2011 at 1:42:24 PM | Load Family button does not pull open the file browser
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I just tried to repair the installation...still no luck.
Wed, May 4, 2011 at 1:48:18 PM | Load Family button does not pull open the file browser
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Tried disabling my other display. Still......no luck.
Wed, May 4, 2011 at 1:55:39 PM | Load Family button does not pull open the file browser
#11
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
I got it! I had to audit the file then retry the keyboard commands for moving the window. Thanks everyone!
cannot find the load family button
Thu, Jun 23, 2011 at 9:24:42 PM
cannot load families into my project
Tue, Aug 15, 2006 at 2:20:22 PM
creating a family
Sat, Jan 17, 2009 at 5:03:04 PM
Cannot Load Components from Library
Wed, Jun 1, 2016 at 6:31:17 AM
Finding open views in Project Browser
Wed, Apr 22, 2015 at 10:31:37 AM
Page generation time: 2.2594
