Forums >> Revit Building >> Technical Support >> sculptured walls- like Mr GG's tutorial but vertical
Mon, Oct 24, 2005 at 5:24:48 PM | sculptured walls- like Mr GG's tutorial but vertical
chrisd2
I am having problems finding an easy way with the pattern running vertically. The effect I am trying to achieve is Norfolk boarding but a composite metal pannel with a vertical profile of 200mm wide, then 50mm wide setback 30mm, for the height of the wall. I expect the solution is straight forward but I cant see it
Mon, Oct 24, 2005 at 8:22:51 PM | RE: sculptured walls- like Mr GG's tutorial but vertical
eldados
eldados Avatar
4.5 Stars: 8 Votes
could you sketch what you have in mind? and will try to help Smile
Integrator
KarelCAD
Tue, Oct 25, 2005 at 3:43:59 PM | RE: sculptured walls- like Mr GG's tutorial but vertical
chrisd2
Thanks for the interest, the attached image shows the required effect. The planks are about 200mm wide by 25mm thick and 50mm apart. They are straight edged. Shadow is an important part of the design.
Tue, Oct 25, 2005 at 5:10:56 PM | RE: sculptured walls- like Mr GG's tutorial but vertical
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Two options, Apply them as wall sweeps placed vertically... OR my preferred method use a curtain wall that gives the appropriate pattern... For instance, a 200x25 mullion could be placed in a system that spaces the grids out at 250mm vertically, then where you windows/doors are, break the curtain system and place a wall to the appropriate thickness (doesn't really matter what wall you use as the window is going to fill the whole section) to act as a host for the window.
Tue, Oct 25, 2005 at 6:31:24 PM | RE: sculptured walls- like Mr GG's tutorial but vertical
eldados
eldados Avatar
4.5 Stars: 8 Votes
I have to say that I would go with curtain wall system as well, would be easier around doors and windows...
Integrator
KarelCAD
Thu, Oct 27, 2005 at 1:01:11 PM | RE: sculptured walls- like Mr GG's tutorial but vertical
chrisd2
Thanks for your help. its much easier than the sweeps and reveals I was trying.
Partial Vertical Reveals in Vertically Compound Walls
Thu, Jul 24, 2008 at 1:04:53 PM
Revit Can't cleanup walls with Modified vertical structure
Fri, Mar 7, 2014 at 11:34:30 AM
Rotaing walls about their vertical axis
Tue, Jul 11, 2006 at 12:06:17 PM
Sketch up - where's the tutorial
Tue, Aug 25, 2009 at 6:47:34 PM
Curtain wall vertical mullions won't go vertical
Mon, Apr 15, 2013 at 6:19:36 AM
12
Page generation time: 1.2547
